Replacing Hinges on Double Glazing - Cannot Turn Some Screws
BrendanChandler
by BrendanChandler » Mon Jul 28, 2014 1:15 pm
I have a sophisticated hinge system on my double glazing.
One side of the hinge attaches to the window and the other side of the hinge runs in a metal track (aluminium?) which is screwed to frame.
I need to remove the track to replace the hinge because a spacer is broken but I cannot turn some of the screws. The screws 'look' like stainless steel.
I have sprayed with WD40, Tapped the Screw with hammer, tried to tighten.
Any advice would be very welcome.
Brendan
Re: Replacing Hinges on Double Glazing - Cannot Turn Some Screws
by welsh brickie » Tue Jul 29, 2014 1:53 pm
try using a drill, cordless preferably at its lowest setting and slowest speed giving you maximum torque, spray the screws with wd40 fast release penetrant spray before attempting to remove them
It is currently Wed Jan 08, 2025 12:48 pm
