Replacement Cover for Consumer Unit to Cover Newly Installed MCB
6 posts   •   Page 1 of 1
brimble
by brimble » Fri Aug 08, 2014 3:24 pm
Having just replaced cartridge fuses for MCB,s I find that the original fuse cover is to shallow to cover the new mcb. Where is it possible to obtain a deeper cover.
Reevio
Re: Replacement Cover for Consumer Unit to Cover Newly Installed MCB
by Reevio » Fri Aug 08, 2014 7:57 pm
Can't you cut the cover ?
brimble
by brimble » Sat Aug 09, 2014 12:57 pm
Thanks Reevo I have considered that but it would destroy the existing cover so I am going to find suitable material to build up the existing cover to give suffucient depth for the MCB,s
plumbbob
by plumbbob » Mon Aug 25, 2014 7:20 pm
In most cases the front cover is cut to allow the mcb's to protrude through. It was very popular with the most common older Wylex consumer units.
If you do build the cover out, remember to allow enough space for the mcb lever to trip.
brimble
by brimble » Tue Aug 26, 2014 8:56 am
Thanks Plumbob for your guidance and I am now in the course of building up the cover..
Regards Brimble
BHS_john
by BHS_john » Fri Nov 21, 2014 10:34 am
plumbbob wrote:In most cases the front cover is cut to allow the mcb's to protrude through. It was very popular with the most common older Wylex consumer units.
Thank you so much! You really helped me :)
It is currently Sat Nov 23, 2024 9:33 pm
