by proptech »
Mon Aug 11, 2014 7:38 pm
Put it this way, my own open system is now about 30 years old. When I installed it, although the components for a pressurised system were available, I chose to go for open in common with most of the systems we were installing at the time for the sake of simplicity. I did not want a pressure vessel, filling loop, and gauge in the airing cupboard.
OK, I'm lucky to have a loft for the tank, and it would be unlikely to freeze up, but I know that the pressure is always constant, and as the design is correct there will not be any problems.
In all these years I have not had sludge problems, replacement valves etc, and a new boiler, yes, but not sludge.
I'm not trying to say anything against sealed systems, just being a bit old fashioned !
Back to your problems - I can't understand how someone can change a boiler knowing full well that there are problems with a system, and do nothing about it. Even the plastic pipes can cause sludge if of the wrong type.
The whole system needs to be inspected in detail, and all remedial work carried out by a competent heating engineer. He may well suggest converting to a sealed system anyway as they are generally not so critical of system design.
