Fitting towel rail in place of radiator in bathroom - no water!
kennymcd
by kennymcd » Sat Aug 09, 2014 10:43 pm
I want to fit a new towel rail in place of radiator in bathroom. I have a Combi Boiler system.
I have closed off both valves on radiator, drained the radiator and removed radiator from wall. With the radiator off I opened both valves to check that water was coming out but no water came out of either. Is this normal with a Combi boiler and how do I get the water to come back when I have fitted the towel rail. Thanks
proptech
Re: Fitting towel rail in place of radiator in bathroom - no water!
by proptech » Sun Aug 10, 2014 6:34 pm
Hi kennymcd
Are you absolutely sure that both valves were fully off when you drained the rad? I think that maybe one of the valves may have been 'letting by' and you have therefore reduced the pressure, and partially drained the system. Check the pressure gauge.
It is currently Thu Jan 09, 2025 3:29 pm
