Repairing and levelling concrete bathroom floor should I line with damp proof membrane?
buzzofyaxley
by buzzofyaxley » Fri Aug 15, 2014 7:50 pm
Upon removing my bath panel i found this mess which i need to level in order to fit a new bathroom suite. It appears to be the foundations as its a very coarse concrete mix. The rest of the bathroom is smooth and level concrete. The step is approx 2.5 inches deep, so i have the following questions.
Should i line the recess with a layer of damp proof membrane before i level it?
Also, what cement mix should i use for this and should i finish it off with a skim of floor levelling compound?
Appreciate your suggestions.
Jon
IMG_2273 (380x285).jpg (87.72 KiB) Viewed 2978 times
[img]
[/img]
IMG_2272 (400x300) (380x285).jpg (88.98 KiB) Viewed 2978 times
Re: Repairing and levelling concrete bathroom floor should I line with damp proof membrane?
by welsh brickie » Sat Aug 16, 2014 10:06 am
just use sand and cement 4 to 1 ratio, to fill in the gaps, the membrane will be under the concrete, this is a screed that it laid over the top, I would then lay a self level compound over the entire floor
buzzofyaxley
by buzzofyaxley » Sat Aug 16, 2014 11:08 am
Thanks very much.
buzzofyaxley
by buzzofyaxley » Sat Aug 16, 2014 11:10 am
Thanks very much.
It is currently Mon Dec 23, 2024 11:58 am
