advice on building materials for bunk bed and fixtures
barnsley
by barnsley » Sat Sep 06, 2014 5:37 pm
I want to build a bunk bed.
I'm not confident on the fixtures to be used.
I'm thinking of using
4 posts @ 2x4inch (or 3x4)
4 side rails at the bottom also 2x4 or (1x6?)
FIXINGS - for side rails to posts:
1x Hex Bolt Zinc Plated 10 x 120mm (or will I need 2 to connect each side rail to each post?)
p.s. This is going to be a double decker bus design so I'm going to attach 12mm thick plywood all around the bunk bed (this will also brace the frame and add extra strength).
I think i will notch out 1inch of the deepest part of the 2x4 post to the side rails which connect to this side.
does this sound feasible?
barnsley
Re: advice on building materials for bunk bed and fixtures
by barnsley » Sat Sep 06, 2014 9:19 pm
change of plan,
I've just seen some cheap timber at B&Q:
£2.44 38x63x2440mm
or 2.5"x1.5"
I figured I could make an L shape on each corner (using 8 of these as posts).
I could use 6x65mm or 5x75mm screws to join 2 of these together.
Hoping I could still use the same size timber for most of the horizontal side rails too which connect to the posts?
It is currently Sun Dec 22, 2024 3:33 pm
