Best Method to Fix Door Frame to Side of House
Codhod57
by Codhod57 » Thu Sep 18, 2014 10:13 am
Hi,any advice i have just fenced the side garden of my house and i am wanting To know what is the strongest way i can fix a door frame to the side of house which has had tExternal wall insulation: – 100mm thick weather proof decorative treatment . applied so i can fix a back gate so i can fix the door frame,what bolts can i use, i have used 150mm coach bolts going through the frame into wall but it not holding tight.
TheDoctor4
Re: Best Method to Fix Door Frame to Side of House
by TheDoctor4 » Mon Mar 09, 2015 5:29 pm
Instead of fixing to the side of the property, is it possible to fix to the ground? Could you fix a fence post to the ground either using a bolt down bracket or even sinking the post down into the ground for a couple of feet and possibly concreting in as this will give you a sturdy and solid point to build a frame off of?
Kind Regards
It is currently Fri Jan 10, 2025 3:46 pm
