SOS Bath Plug Leak After Undoing - Can you Replace the Seal?
DIYSOS
by DIYSOS » Mon Sep 22, 2014 6:06 pm
hi,
the bathwater was draining slowing so I bought some Rhino sulphuric acid from robert dyas to see if it would help. unfortunately it's ruined the stainless steel plug hole cover thing. (see pic)
Foolishly, I undid the screw that goes through the middle to see if I'd be able to fit a replacement. I think i've broken the seal because it now seems to be leaking very slightly from underneath :-(
Does anyone know if I can buy a replacement plughole cover (pic attached) and if I can fit it myself? Will I need a washer or special product to seal it? I know NOTHING about plumbing and DIY. The handyman wants £85 call out.. any help gratefully received. I did a google search but not sure what it's called!
proptech
Re: SOS Bath Plug Leak After Undoing - Can you Replace the Seal?
by proptech » Tue Sep 23, 2014 7:37 pm
Hi DIYSOS
You'll need to access under the bath. The lower part of the waste fitting will have a washer to seal against the bath. A good smear of Fernox LS-X on both sides of the washer should sort the problem.
As you say the existing fitting is ruined, replace the whole waste fitting using the same sealant.
It is currently Sat Jan 11, 2025 11:43 pm
