Connect Trap to Waste Pipe Inlet and 40mm Push Fit Waste Pipe
Cymrodor
by Cymrodor » Tue Sep 23, 2014 7:10 pm
Bottle traps appear to be designed to connect directly to the waste plug of the basin or whatever with a thread that the trap nut screws onto. However, I want to connect the trap inlet to the end of a 40mm push fit waste pipe, which doesn't have a thread. What am I to do?
plumbbob
Re: Connect Trap to Waste Pipe Inlet and 40mm Push Fit Waste Pipe
by plumbbob » Tue Sep 23, 2014 10:49 pm
There are several options, but the easiest is to purchase an adjustable height trap and remove the section that fits to the underside of the basin and replace it with a standard piece of push-fit waste.
Cymrodor
by Cymrodor » Tue Sep 23, 2014 11:04 pm
As it happens, I also have a telescopic bottle trap for another purpose and while waiting for a reply here I had a look at it and discovered exactly what you suggest. Always nice to have a second opinion confirm a plan's a good one. Diolch.
plumbbob
by plumbbob » Wed Sep 24, 2014 8:48 am
Great you solved the problem.
It is also possible to make a washing machine trap from an ordinary "P" trap.
It is currently Mon Nov 25, 2024 9:58 am
