Reinforce Half Brick L Shape Wall Inside Property - Advice Needed
bouba
by bouba » Mon Sep 29, 2014 1:15 pm
I have been told to reinforce half brick L shaped wall inside my house. What is the best way to do this.
I understand I have to tie in a pillar at the end. Do i just use wall starter kit at one end and make it 9" wide or will just a pillar be enought. Wall is 1.5 metre long and 2.4 metre high.
Re: Reinforce Half Brick L Shape Wall Inside Property - Advice Needed
by welsh brickie » Mon Sep 29, 2014 7:19 pm
By the sounds of it you will need to use screw ties along the walll every 3 courses of brick to tie in the length of the wall aswell space them every 450mm
It is currently Fri Nov 22, 2024 12:37 am
