Fitting a Flat LED Ceiling Panel into a Wall - What Fixing to use?
Jess1485
by Jess1485 » Sat Oct 04, 2014 7:11 pm
I would like to fit an LED panel which is designed for a ceiling, into a plasterboard wall.
The fittings supplied with the panel rely on gravity to hold the panel in place, which clearly will not work on a wall. Any ideas of a fixing I could use to solve this problem? I want the panel to be flush in the wall.
Thanks.
proptech
Re: Fitting a Flat LED Ceiling Panel into a Wall - What Fixing to use?
by proptech » Sun Oct 05, 2014 6:26 pm
Hi Jess1485
I'm sure we can sort something, but what fixings have been supplied ? perhaps you could post a photo of the fitting showing the problem.
It is currently Mon Nov 25, 2024 6:36 pm
