Honeywell 2 port valve stays open even after the thermostat is no longer calling for heat. Only way I can get it to the closed position is turning the cylinder / control board off and then on again, which seems to kick the motor back to life. That is until I get into the same situation when the thermostat calls for heat again.
New 2 port needed? Or is it just the motor? Or something else?
