Install Multifuel Burner but Fireplace Chimney not in Center?
radmiller
by radmiller » Mon Oct 06, 2014 7:14 pm
im wondering if anyone can help i want to install a multi fuel burner in place of my open coal fire. i havent started work yet ive been doing alot of research first. When i looked up my chimney from inside my house it seems to go straight up a few inches then veer off to the left then straight up!
If i open up the fire place would i need to install an off set flue adapter or is their anyway to make it centered?
Re: Install Multifuel Burner but Fireplace Chimney not in Center?
by welsh brickie » Tue Oct 07, 2014 6:37 pm
You have to have it installed by a hetas engineer he will check it for you
It is currently Fri Nov 15, 2024 7:22 am
