Banging Pipes for Bathroom Sink Taps - What Could be the Cause?
6 posts   •   Page 1 of 1
TracyJane1
by TracyJane1 » Tue Oct 14, 2014 4:50 pm
My bathroom sink taps have the following issues:
Cold tap
When the tap is first turned on there is a lot of what seems like built up pressure and the water comes out too fast.
Hot tap
Starts off ok but gradually starts to whine then turns into a rhythmic banging. It stops if I turn the tap on full pelt.
Please help!
proptech
Re: Banging Pipes for Bathroom Sink Taps - What Could be the Cause?
by proptech » Tue Oct 14, 2014 9:10 pm
Hi TracyJane1
Cold tap problem sounds like there's a 'dead leg' somewhere on the system containing air. As far as the hot is concerned, please give us some more info as to what system you have , and how your water is heated.
TracyJane1
by TracyJane1 » Tue Oct 14, 2014 11:51 pm
Thanks for replying Proptech
Direct water system/combi boiler I believe
proptech
by proptech » Wed Oct 15, 2014 11:19 am
In that case, the hot tap probably has a loose washer, or worn mechanism. Not much more I can say without more details of the problems.
TracyJane1
by TracyJane1 » Wed Oct 15, 2014 11:28 am
Extra info:
I've noticed that the flow of water on the hot tap slows by itself after about 20 seconds and that's when the banging starts.. Turn the tap up full and it stops
proptech
by proptech » Wed Oct 15, 2014 6:46 pm
yes, that's a tap fault.
It is currently Sat Nov 23, 2024 8:23 pm
