New Pillar to Tie in to Existing Walls to Support RSJ for Opening
bouba
by bouba » Tue Oct 21, 2014 9:37 am
SE has advised to use 13" brick pillar under rsj for opening.
House walls are solid 9". How do i build a pillar and tie it to the wall.
Can anyone show me a diagram or something. Could I wrap around the pillar.
Re: New Pillar to Tie in to Existing Walls to Support RSJ for Opening
by welsh brickie » Tue Oct 21, 2014 7:01 pm
You can tie the brickwork in using a starter kit that you drill and fix into the existing brickwork see www.screwfix.com/saberfix wall starter kit
bouba
by bouba » Tue Oct 21, 2014 8:29 pm
Thamks WB. So you are saying if I drill both sides of a 9" solid wall end with a wall starter kit ,and build a pillar around it will be fine.
Just wondering what to do with the foundation. If I am digging for wall foundation at a 1mtr depth around the wall,is it possible to put concrete at the same depth for the wall whose foundations are shallow (1930house). Will it reinforce the present wall,but a small section only.
by welsh brickie » Sat Nov 01, 2014 6:01 pm
If you dig down to the original house foundation depth it should be fine, but the inspector has to approve it before concrete is poured
It is currently Sun Nov 24, 2024 7:17 pm
