by Sheffordian »
Tue Nov 04, 2014 3:53 pm
I'm hoping one or more experts on here can help me. I am gradually switching over to LED bulbs and all has gone well so far including one bulb on a dimmer switch. However, the lounge lighting unit consists 3 bulbs which were Philips Eco each at 18w (clear candle E14). I have replaced with 3 Ledlam 4 Watt LED warm white dimmable bulbs. Because of poor light and flickering I then changed the dimmer switch to a trailing edge dimmer switch but the lighting is still very erratic. The bulbs do not come on instantly and when they do come on they flicker like crazy except when at the lowest light setting. There is the dimmer switch at one point and a straight on/off at the other. The dimmer is two gang with the dining room light worked by one gang (the successful LED/dimmer) and the lounge light controlled (?) by the other. Frustrating the hell out of me and I was lucky enough to trip over this forum and hope that help is out there.
