What Pipe Cutter to use for Cutting Soil Pipes?
Willhelm
by Willhelm » Wed Nov 05, 2014 12:21 pm
Hello guys,
wich pipe cutter do you use to cut soil pipe/cast iron?
something like this?
thanks for your answers,
Willhelm
proptech
Re: What Pipe Cutter to use for Cutting Soil Pipes?
by proptech » Thu Nov 06, 2014 10:26 am
Hi Willhelm
Please tell us what you intend cutting. If this is just a domestic situation, the only cuts are likely to be those needed to remove the pipe for replacement.
Martinck
by Martinck » Thu Dec 11, 2014 12:10 pm
Soil pipe cutters can be used. This method can be used to cut uninstalled pipes. It can also be used to cut pipes that are already installed but need to be repaired .
It is currently Wed Jan 08, 2025 10:13 pm
