Will my idea work,
I have always had a low pressure problem with my triton 300i 10.5 kw shower but only when water is being drawn off somewhere else, Im just about to make it a lot worse, Ive had an extention built and intend having a wet room / ensuite built, I know for sure that i will never be able to have both showers running with no consequences , but I have a cunning plan, can you tell me if this will work. I propose to change the water feed to the electric shower from the mains supply to a cold water tank yet to be installed in the loft. I propose to fit an electric pump to the supply to the shower, I will also fit an isolating valve to the supply to the tank so it dosent fill up whilst showering, this will be switchable perhaps when i go to bed at night to let if fill up ( when there are no water deamnds) The second shower yet to be built, would be fed by normal pressure and thermostatic mixer valve direct from the combi boiler.
