Power shower water pipe size - is 15mm ok to use?
Wenney
by Wenney » Fri Nov 14, 2014 9:46 pm
Hi guys I am about to fit a power shower I have 22 mm pipe from tank to pump and then to the mixer valve my question is the mixer valve looks like the fitting from the valve to the shower head is 15mm pipe is this ok or do I need to step it up to 22 mm . Hope someone can help this is my first step in to plumbing so sorry if this sounds a bit dim.
proptech
Re: Power shower water pipe size - is 15mm ok to use?
by proptech » Sat Nov 15, 2014 6:39 pm
HI Wenney
As long as you have used 22 to the valve, all should be OK.
Wenney
by Wenney » Sat Nov 15, 2014 11:43 pm
Thanks got quite a bit done to day so your reply came in time should be able to get started with the piping tomorrow once again thank you
It is currently Sat Jan 11, 2025 11:01 pm
