Replacing old Light Switch - Which Terminals do Live Wires go to?
6 posts   •   Page 1 of 1
Ian73
by Ian73 » Wed Nov 19, 2014 1:05 pm
I'm replacing a light switch that works two spotlights with two cables coming down into the switch only 2 live wires are showing one from each cable
At the switch there is no earth and the neutral goes from one cable to the other
which terminals on my new switch do the live wires go into eg 1 way,2 way or common.......thanks
Re: Replacing old Light Switch - Which Terminals do Live Wires go to?
by ericmark » Wed Nov 19, 2014 9:46 pm
In the UK it is unusual to have a neutral at the light switch. In the main all wires should be brown or covered with brown sleeving but it has been known to fall off.
Ian73
by Ian73 » Thu Nov 20, 2014 8:57 am
Ok thanks the light switch I took off was a real relic made of pot and a brown bakelite casing in the switch it had the two red wires in opposite terminals but it didn't say on it which was which
The only other wire visable was a black one which I presumed was neutral
that one wasn't connected to the switch at all but went like a loop from 1 main cable to the other......thanks
by ericmark » Fri Nov 21, 2014 5:21 am
It does not need to say which red wire is which it will work either way around.
Ian73
by Ian73 » Fri Nov 21, 2014 6:56 pm
ok cheers
Ian73
by Ian73 » Fri Nov 21, 2014 7:13 pm
Yeah sorry I meant the old switch terminals didn't have any letters or symbol's on them so I couldn't use it for a reference when fitting the new switch
It is currently Thu Jan 02, 2025 3:45 pm
