Can you Screed over Linoleum Tiles?
dandoitall
by dandoitall » Fri Nov 21, 2014 11:02 pm
Is it possible to screed over linoleum floor tiles and if so how
Re: Can you Screed over Linoleum Tiles?
by welsh brickie » Wed Nov 26, 2014 5:05 pm
yes, If its a concrete floor use a strong pva solution on the floor and remove any loose pieces, then when dry, lay a latex self level compound over the entire floor. If its a wood floor, you need to glue ply over the top and screw it down securely then lay the tiles with a flexible adhesive
It is currently Fri Nov 22, 2024 6:57 am
