Upvc Door and Frame - Should Door Touch Frame Seals Evenly?
Ronaldt
by Ronaldt » Wed Nov 26, 2014 7:47 pm
When you close the door, should the door be touching the frame seals evenly all round, i have been told by the installer that there should be some tolerance even though parts of the door are tight and there are gaps elsewere. This is a new installation
Re: Upvc Door and Frame - Should Door Touch Frame Seals Evenly?
by welsh brickie » Sat Nov 29, 2014 8:53 pm
all upvc doors will have a bend in the profile, the door should shut ok, but when you lift the handle the whole door should compress against the rubber gasket
It is currently Mon Dec 23, 2024 9:48 am
