150 Litre Horizontal Boiler Dropped From 6ft - is it ok?
mccsandi
by mccsandi » Thu Nov 27, 2014 8:20 am
Our new electrical 150 litre horizontal boiler was not secured properly and fell 6 ft. It has been re-installed and appears to work but I'm concerned that it has internal, no visible damage that could be dangerous or cause future problems. Should we replace it ?
Re: 150 Litre Horizontal Boiler Dropped From 6ft - is it ok?
by htg engineer » Mon Dec 22, 2014 12:27 pm
Entirely up to you, as you don't give the make model it's not possible to give advice on things to check.
If it's a cylinder with electrical connections, I would check for leaks, get an electrician to check electrical components, if they're okay then there's no need to replace.
mccsandi
by mccsandi » Mon Dec 22, 2014 3:16 pm
Thank you for your response. Much appreciated.
It is currently Thu Jan 09, 2025 1:50 am
