Replace Top Oven Seal in Parkinson Cowan to Prevent Heat Escape
etaf
by etaf » Mon Dec 01, 2014 2:32 pm
Parkinson Cowan L55GX2WN top oven seal replacement
Brand: Parkinson Cowan
Model Number: L55GX2WN
The top oven seal has hardened and part of it has come away - so the heat is escaping and making the controls quite hot
I have received a replacement seal today - BUT looking at the cooker seal - its not obvious how this is removed / replaced
it appears to be locked in-between some metal plates and I'm hoping this does not involve dismantling the top oven
Anyone know how to replace this seal please
DIYDoctor1
Re: Replace Top Oven Seal in Parkinson Cowan to Prevent Heat Escape
by DIYDoctor1 » Mon Mar 09, 2015 3:25 pm
Hi Etaf,
I would recommend calling the company that sold you the seal as they should be able to assist you, and if that can't should be able to point you in the direction of someone that can.
It is currently Thu Nov 21, 2024 9:10 pm
