Fitting a 60w Bulkhead Light outside - Few Pointers Needed
jimmythemoonlight
by jimmythemoonlight » Thu Dec 18, 2014 11:18 pm
Hi All
I want to fit a Bulkhead Light outside using a plug and socket my question : is 2 core lighting cable sufficient or do I have to use 3 with an earth also will a 5 amp fuse be sufficient. it will be well under cover from the weather thanks
jimmythemoonlight
Re: Fitting a 60w Bulkhead Light outside - Few Pointers Needed
by ericmark » Fri Dec 19, 2014 1:04 pm
Electrical equipment comes with 3 classes forget Class III that's extra low voltage which leaves two classes. Class I requires an earth and Class II does not require an earth. With class II it will always be marked often a double square sign. It will depend on the fitting as to if earth is required or not. If Class I earth is required if Class II it is not.
Size and type of bulb will determine size of fuse required. Since planning permission required for over 150W I would assume it would be 150W or less and 1A = 230W so a 1 amp fuse is big enough. There are two preferred sizes of fuse which are 3A and 13A so I would expect to find a 3A fuse fitted.
It is currently Mon Jan 13, 2025 6:24 pm
