Briston shower valve - how to remove end cap on mixer?
Gnomeathome
by Gnomeathome » Sat Dec 20, 2014 10:12 am
Can anyone advise me on how the end cap on this mixer is removed please? Does it screw off? Or do you pop it off with a screwdriver or knife? The valve has become very stiff and was probably not lubricated when the cowboy fitted it!
Re: Briston shower valve - how to remove end cap on mixer?
by htg engineer » Mon Dec 22, 2014 10:04 am
Valves vary depending on make and model, the caps normally do just pop off with the use of a screwdriver or similar, then there'd normally be a retaining nut or screw underneath. Have you tried Googling the make and model to see if you can find the installation/servicing instructions?
It is currently Wed Jan 08, 2025 10:04 pm
