uneven wooden floor
rich2000
uneven wooden floor
by rich2000 » Sun Aug 05, 2007 6:41 pm
HI folks,
I recently had a solid wooden floor put down in my dining room (3 strip oak) However it seems that the fllor is now uneven with humps appearing every 3 or 4 boards where they join.
What could be the reason for this and how could it be remedied?
hope someone can help thanks
richard
by htg engineer » Thu Aug 09, 2007 5:01 pm
was there a gap left around the edges between the flooring and the walls ? wood will expand and shrink slightly depending on the heat, humidity etc of the room,
rich2000
tight floor boards
by rich2000 » Mon Aug 13, 2007 9:14 am
hi thanks for the reply.
there was a gap left but evidently not enough. I removed the skirting board and in places the timber was tight to the wall. So obviously it had expanded so far and then couldn't go any further.
If i just cut 5-10mm off round by the edges will the floor level itself out again?
cheers
rich
It is currently Fri Jan 03, 2025 1:59 am
