Garage Conversion into Storeroom and Office - Advice Needed
TheMightyAtom
by TheMightyAtom » Mon Jan 05, 2015 6:22 am
I would like to convert our garage into a storeroom/office.
I am new to DIY and from reading on the web I understand the first thing to do is insulate and then cover with a chipboard floor.
I hope someone can advice on the following:
[list=]How far apart and what thickness should I make the floor joists?
What would should I make the joists from?
What is the correct insulation to use?
Do I need a damp proof membrane on both sides (the side nearest the concrete slab and the side nearest the room)? [/list]
Thanks in advance for your help.
DIYDoctor1
Re: Garage Conversion into Storeroom and Office - Advice Needed
by DIYDoctor1 » Mon Mar 09, 2015 2:11 pm
Hi TheMightyAtom,
A good place to start with this question is here: https://www.diydoctor.org.uk/projects/garage.htm
Regarding your flooring and the joists, there is a lot of information available here: https://www.diydoctor.org.uk/diy-how-to- ... ooring.htm
Regarding your other questions, it will depend on what is already there. Find out more about damp proofing a garage floor here: https://www.diydoctor.org.uk/projects/ga ... pfloor.htm
And for more general information on garages have a look at the section here:
https://www.diydoctor.org.uk/diy-how-to- ... ilding.htm
Hopefully that will give you a good start - good luck with the project!
It is currently Thu Jan 09, 2025 9:32 am
