by cinn »
Wed Jan 07, 2015 11:03 am
I am in the process of converting a garage into a games room with a dual power supply. There is an existing mains supply with an old consumer unit in the garage. This is connected to a 17th edition unit in the main house as well. Additional to this, I have installed an off-grid photovoltaic system to the garage roof and installed dedicated power outlets from a 5kW inverter. At present this system is not earthed which, as it is providing 230 v AC, it probably should be. My question is: can I connect the grounding point of the inverter to the earth bus bar in the garage consumer unit? If so, should I use earth wire or 2.5mm wire? Or, should I purchase a grounding stake and clamp? Again, earth wire or 2.5mm connection?
