Whirlpool Hob Ignition Switch - How to get the Switch Cover off?
bxcfilm
by bxcfilm » Tue Jan 13, 2015 2:39 pm
I have a Whirlpool AKP511 built-in electric oven / gas hob, which has worked fine since 1998, but now the ignition switch is starting to spark less and less. I have cleaned it as far as I can, but I can't get the switch cover off. I have tried as hard as I dare to prise it off, but no luck. My first question is: I suppose it is meant to be levered off like this...? If not like that, then how?
The second question is whether I can get a replacement switch, if I need one. The top of my switch looks like this one,
but I have no idea about compatibility. I haven't found anywhere supplying a switch for the AKP511.
I would appreciate any help.
proptech
Re: Whirlpool Hob Ignition Switch - How to get the Switch Cover off?
by proptech » Tue Jan 13, 2015 7:24 pm
Hi bxcfilm
Although I'm not familiar with that model, I would be very surprised indeed if the fault you describe was caused by the switch. Most likely the spark generator. I really would suggest getting the help of a registered engineer to correct this, as there should be no DIY work on a gas appliance.
bxcfilm
by bxcfilm » Wed Jan 14, 2015 8:48 am
[After switching off the power, of course], I cleaned around the switch cap as best I could. Food gets in there every so often, and I couldn't help thinking that the problem may be as simple as dirt on the contacts. I also sprayed some switch cleaner. It now works a bit better, a spark reliably about once a second, which is enough. Bottom line - it's now doing the job.
But I agree about your main point - if it needs any further work, I would need to get a fitter in.
But I still don't know where I would be able to get a switch.
It is currently Mon Nov 25, 2024 5:30 pm
