Fixing an LCD TV to a Dry Lining Wall
petemoon
by petemoon » Sun Aug 05, 2007 9:22 pm
I am trying to fix my 37" TV to an external wall which I believe has dry lining in it and I cannot therefore use the brick rawplugs supplied with it. The TV weights 30kg and I have been told if I use the heavy duty plasterboard plugs this will hold it.
Can you offer any advice with this.
Thanks Pete.
misterg
by misterg » Thu Aug 09, 2007 10:13 pm
I'm not sure just fixing to the plasterbaord along is sufficient.
Ideally t would be better to put a noggin in the wall, but this would mean cutting a large hole in the plasterboard and making good afterwards.
If you don't want to do that, then at least try to locate one of the screws in a stud.
Hope this help.
G
It is currently Fri Nov 22, 2024 3:18 pm
