Fixing Wooden Greenhouse Base to Paving Slabs
RudyBook
by RudyBook » Wed Feb 04, 2015 6:16 pm
Hello,
I have a 12x6" wooden greenhouse to erect. I am placing it on a base on top of level patio slabs. However, I do not want to concrete the base in to secure it as I may wish to dismantle it if we move house.
The paving slabs are 4cm thick.
Is there a way I can brace the base, and therefore the greenhouse, onto the paving slabs? Some kind of bracket for drilling Into the slab?
thedoctor
Re: Fixing Wooden Greenhouse Base to Paving Slabs
by thedoctor » Mon Mar 09, 2015 1:11 pm
To be honest a12 ft x 6ft structure,on top of a (presubably) timber base which is sitting on a level surface should not move anywhere, fixed or not.
You don't say how thick the greenhouse base is but if you are worried then there is no reason why you should not drill through it andplug and screw it into the slabs. Make sure the screws go into the middle of the slabs, if they are too close to an edge it could break away. See our project page on fixing to masonry here. The page is about fixing to walls but the same principle applys to floors
https://www.diydoctor.org.uk/projects/fi ... asonry.htm
It is currently Thu Dec 05, 2024 4:20 am
