Removing Stone From a Fireplace - Might Have Gone too Far
underwater sunlight
by underwater sunlight » Sat Feb 21, 2015 3:20 pm
We are having our living room plastered and our existing fireplace rendered. We are in the process of removing the stone cladding around the fireplace to expose the brickwork. Above the fireplace there was a 2in thick stone slab which we removed before realising there are no bricks behind it and now there is a large gap where the likelyhood is that the smoke will release into the room rather than up the flue and out of the chimney.
We removed the stone because the bottom of it came out further than the existing stonework and as the render will not be as thick as the cemented stones (we were going to render iver the big stone in question too which would have made it protrude even further) we didn't want it to look daft.
Posting on my phone so a picture will follow but might take a few minutes.
Any help/advised will be greatly appreciated
thedoctor
Re: Removing Stone From a Fireplace - Might Have Gone too Far
by thedoctor » Mon Mar 09, 2015 12:45 pm
No image came through whic makes it tricky but it sounds like the stone may have been acting as a lintel as well. This means it needs to go bac but while it's out you can hire a disk cutter and cut it down lengthways so when it goes back it does not protrude.
It is currently Fri Nov 15, 2024 9:31 am
