Large Crack Between Wall and Ceiling Found After Removing Coving
Liam1978
by Liam1978 » Sun Feb 22, 2015 7:58 pm
I just removed the some old and damaged coving and there is separation between the ceiling and the walls as per the picture. As you can see there is also a bit of a damp issue. If I push the ceiling up the crack gapes even more.
I'm a bit of a DIY novice, can anyone recommend the best course of action. Is it just a case of using the right filler or does it require professional attention.
I'm planning on getting the ceiling skimmed and replasterrd anyway. Is it something a professional plasterer could rectify?
Any advice would be gratefully received.
Liam
Re: Large Crack Between Wall and Ceiling Found After Removing Coving
by welsh brickie » Tue Mar 03, 2015 8:07 pm
you can use a mesh called skrim that you can lay over the crack then plaster over
It is currently Sat Nov 23, 2024 8:33 pm
