How to Create 3 Part Retaining Wall - DIY Noob Advice Needed
DIYnoob83
by DIYnoob83 » Mon Feb 23, 2015 12:35 pm
I am looking to create a retaining wall. It will be split into 3 parts.
I need to make 2 1.5ft walls to create a terrace stepping system and there will be a 3ft wall along 1 side of the garden.
I want to know if i need special blocks for this or if I need to use some steel reinforcement.
I assume I should use a gravel foundation and lay the blocks in a backwards leaning motion. Backfill with gravel and then every half a ft put some steel webbing ontop to reinforce the walls strength.
Is this necessary?
Can't I just use concrete foundation, bricks and mortar for a wall less than 3ft? Thanks.
Please click my link to get access to the image file to get a better perspective of what i am trying to do.
https://drive.google.com/file/d/0B4Mn6y ... sp=sharing
thedoctor
Re: How to Create 3 Part Retaining Wall - DIY Noob Advice Needed
by thedoctor » Mon Mar 09, 2015 12:35 pm
6-inch (150mm) concrete blocks willbe ample for these walls. Both the 18-inch and 36-inch flavours. Use a foundation trench 12-inces wide and 6-inches deep, fill with concrete as per our mixing concrete page where you can also work out volumes of materials required. https://www.diydoctor.org.uk/projects/mi ... ncrete.htm
Lay the blocks upright (no need to slant) but consider how you willfinish the top of the wall as you cannot lay turf onto the topof the block so you will need to build the block higher than the garden surface and put some sort of capping onto it. See our page on laying bricks and blocks where you will also find some information on laying coping stones https://www.diydoctor.org.uk/projects/la ... blocks.htm
We have a page on retaining wall advice here https://www.diydoctor.org.uk/projects/retainingwall.htm
Another page on building garden steps here https://www.diydoctor.org.uk/projects/garden-steps.htm
Building garden walls here https://www.diydoctor.org.uk/projects/bu ... enwall.htm
You may also want to visit our page on rendering walls https://www.diydoctor.org.uk/projects/re ... -walls.htm
It is currently Sat Nov 23, 2024 1:37 pm
