Levelling up Wonky Thermalite Wall for Kitchen Wall Units
sheepdisease
by sheepdisease » Fri Feb 27, 2015 1:32 pm
I wondered if you could please help me out as I appreciate your expertise.
I have had three block walls built which don't quite line up and one of them is out of plumb for dividing a lounge/kitchen.
The deviations are approx 1 cm, where one wall is leaning forward towards the top a little and if you look along the walls from side on they are about 1 cm out from flush.
I don't want to start from scratch and was hoping to render the walls so that they all line up plumb in all directions so that I can then dot and dab and then the wall needs to be solid to support the weight of kitchen wall units.
Do you have any advice?
I would use timber batterns if it wasn't for the fact it needs to be strong.
Thanks for your help in advance.
Re: Levelling up Wonky Thermalite Wall for Kitchen Wall Units
by welsh brickie » Tue Mar 03, 2015 8:03 pm
attach a timber batten to the wall where your units need to be, pack it out till its straight.
Dot and dab the plasterboard to the level of the batten.
It is currently Fri Nov 15, 2024 9:51 am
