30mm as opposed to 65mm bricks not blocks
Hodko
by Hodko » Sat Mar 07, 2015 12:18 am
Hi, has anyone come across a standard building brick but with a height of 30mm as opposed to the standard 65mm ?
I have a dwarf wall front sitting under some decking which has a small gap which I'd like to fill. Paving blocks don't match the bricks.
Sure I've seen some somewhere but can't remember where
Re: 30mm as opposed to 65mm bricks not blocks
by welsh brickie » Sat Mar 07, 2015 4:20 pm
you can split the brick in half using a diamond disc cutter or by hand using a bolster and club hammer, you cannot get 30mm thick bricks.
It is currently Fri Nov 15, 2024 9:23 am
