PLastic Bung or Plug stuck in 4inch Drain Pipe - Any Other Options for Removal?
dl7984
by dl7984 » Sun Mar 08, 2015 8:13 pm
Hello
I have a drain bung that is stuck in a drain that I am looking to connect to a new toilet. As seen in the image it is 5m in from the manhole and is in a drain that is 4 inches wide.
I have had engineers come around and attempt to remove it using a power flush and with rods. The problem they had with the rods was that there was a curve in the pipe which meant they didn't have a straight run at the blockage and so couldn't get their full force behind it.
I know this can be resolved through an excavation, but I wanted to know if there are any other options available to me.
Many thanks
thedoctor
Re: PLastic Bung or Plug stuck in 4inch Drain Pipe - Any Other Options for Removal?
by thedoctor » Mon Mar 09, 2015 11:45 am
Other than excavation you have two very,very long-shot options. Use drain rods to try and loop a lassoo rope around the thumb screw on the bung or make a hook out of a piece of steel, attach it to a rope and use the rods to try and get the hook round the back of the bung. Both have been known to work but very time consuming indeed.
It is currently Sun Jan 12, 2025 12:58 am
