Best Way of Constructing Concrete Base For Greenhouse
sienewman
by sienewman » Mon Mar 09, 2015 10:47 pm
I'm building an 8x8ft greenhouse which will have a concrete slab floor, the wooden greenhouse will sit on a 2ft high block wall.
I'm wondering which way would be best to do the wall/slab. I have been given conflicting advice on the way I should do the base.
(1) The first option would be to lay concrete blocks on their side and concrete in the middle, then building the wall on top of the concrete block that is laid down.
(2) The second option is to use wooden shuttering to build the concrete slab and then just build the wall on top of the slab.
Which is the best way? Would really appreciate any advice
TheDoctor4
Re: Best Way of Constructing Concrete Base For Greenhouse
by TheDoctor4 » Tue Mar 10, 2015 8:36 am
Have you seen our shed base project?: https://www.diydoctor.org.uk/projects/shedbase.htm
The basic construction methods should be the same so this may help you out
Hope it helps
sienewman
by sienewman » Tue Mar 10, 2015 9:33 pm
TheDoctor4 wrote:Hi
Hope it helps
Thanks! looks like I will work of this plan then :)
TheDoctor4
by TheDoctor4 » Tue Mar 10, 2015 9:59 pm
No problems, glad we could help
Kind Regards
It is currently Fri Nov 22, 2024 9:52 am
