Sticking Edge of MDF Board to a Tiled Wall - What's Best to use?
Zacccc
by Zacccc » Wed Mar 18, 2015 2:56 pm
Can anyone advise on the best stuff to use to stick the edge of an MDF off-cut to tiles?
I've got a bit of a mess of pipes running behind the toilet so I've covered them up by boxing them in using some off-cuts from old MDF kitchen units. I've got the boxing all done but it leans slightly towards the toilet from the tiled wall behind the toilet, leaving a gap of about 7mm between the wall and the edge of the MDF unit that is the 'top' of the boxing. I want to stick this MDF edge to the tiled wall.
Theinsulationshop
Re: Sticking Edge of MDF Board to a Tiled Wall - What's Best to use?
by Theinsulationshop » Fri Mar 27, 2015 8:22 pm
'Fix all' by soudal works really well and comes in a range of colours. It's not a silicone either but you still can't paint over it, but once it dries it's brilliant
It is currently Thu Dec 12, 2024 3:37 pm
