Loft Suitability for Storage Purposes With 3 x 2 Joists at 16 Inch Centres
phatrat
by phatrat » Sun Mar 29, 2015 3:12 pm
H
Thinking of boarding out a loft so it can be used for storage purposes (1930's, Semi Detached, UK) . However I am concerned that it may not be suitable.
The joists are 3 x 2 at 16"centres. Spanning approx 4m.
Any advice would be greatly appreciated.
DIYDoctor1
Re: Loft Suitability for Storage Purposes With 3 x 2 Joists at 16 Inch Centres
by DIYDoctor1 » Thu Apr 16, 2015 12:14 pm
Hi Phatrat,
There are a couple of pages that we have to help you here. Have a quick look over this project to give you an idea of what's involved:
https://www.diydoctor.org.uk/projects/loftstorage.htm
There are a few more projects here: https://www.diydoctor.org.uk/diy-how-to- ... ersion.htm
We also recommend a fantastic product that means that you can add the recommended amount of insulation and still be able to use the space for storage: https://www.diydoctor.org.uk/DIY-superst ... orage.html
I hope that helps!
michaelbailey
by michaelbailey » Thu Jun 09, 2016 6:29 pm
3x2 are not joists for a 4m spsn
michaelbailey
by michaelbailey » Thu Jun 16, 2016 12:59 pm
220x50mm are the sizes @ either 600 or 400mm centres these are sufficient for all uses and approved going to do this work you'll regret not doing it initially
It is currently Thu Nov 21, 2024 8:59 pm
