45amp Cooker Blank Plate - Can I Replace With Standard Chrome Blanking Plate?
Rob Jenkins
by Rob Jenkins » Sun Mar 29, 2015 5:06 pm
For some reason I have a 45amp cooker blank plate (it is deeper at the top than the bottom) in my dining room, it also has a single gang socket directley above it.
I would like to replace both white fittings for chrome.
I have had a good look round but all the 45amp blank fittings are only white.
Can I just fit a standard chrome blanking plate over it?
Many thanks for any help
Re: 45amp Cooker Blank Plate - Can I Replace With Standard Chrome Blanking Plate?
by ericmark » Mon Mar 30, 2015 8:25 am
Clearly the wires need to go some where but likely a 30 amp connector will keep the wires safe so I see no reason you can't fit a blank.
Rob Jenkins
by Rob Jenkins » Mon Mar 30, 2015 10:50 am
45amp internal.PNG (11.78 KiB) Viewed 2721 times
Thanks for the reply.
All the internal wires are out of the way, I was hoping to use the central fixing screws to fit the chrome blank with. Obviously the white cover has off set screw holes.
It is currently Mon Jan 13, 2025 6:40 pm
