Wiring to a Junction Box in teh Attic for Double Socket
redgreen7brown
by redgreen7brown » Tue Apr 14, 2015 7:43 pm
My junction box which is in the attic has enough wires in it. where can I put an extra cable from a double socket?
Re: Wiring to a Junction Box in teh Attic for Double Socket
by ericmark » Tue Apr 14, 2015 11:13 pm
There are some rather complex rules for extending circuits. It depends on the type of circuit so a ring final, a unfused spur, a fused spur, and a radial all have different rules. With radials it also depends on size of cable used.
Job one is to work out what you already have. Using a RCD FCU is likely the best method for DIY extensions but until you know what you already have can't answer the question.
It is currently Mon Jan 27, 2025 9:58 pm
