Is my heating system weird or normal?
slouth
by slouth » Tue Aug 07, 2007 2:38 pm
Hi, I have got a central heating / hot water system that only allows me to have the radiators on if the water has first of all been heated up.
So if I was to turn on the heating straight after the water had been heated then the rads would come on straight away, However if I wanted the heating on say after we had had a bath or a few hours after the water had been heated it will firstly heat the water back up before allowing the rads to come on.
Any advice / ideas on what type of system this is?
Very annoying last winter!
Rulland
by Rulland » Tue Aug 07, 2007 7:12 pm
Hi there, Yep yours is a standard system based on a 2 way valve arrangement,IE your boiler will heat your water or your radiators but NOT at the same time-preference is given by your boiler controller to the hot water.
In a three way valve arrangement the boiler can heat hot water and radiators at the same time.
Regards Richard.
bmplumb
by bmplumb » Tue Aug 07, 2007 7:23 pm
sounds like a thermal store but it doesnt sound as if its working properly
It is currently Sat Nov 23, 2024 2:27 pm
