Identify Pull Cord Ceiling Rose in Bathroom Attached to Fan Extractor
mrDomMarioMan
by mrDomMarioMan » Thu Apr 23, 2015 3:55 pm
I have a pull cord switch in my bathroom which activates a fan extractor, the pull cord has broken and therefore I need to replace it.
I thought I could just replace the switch with a lighting ceiling rose pull cord.
I went ahead and purchased it , however when I took the cover off and compared it I noticed that the wiring is completely different.
Could some one take a look at the photo of the existing switch and identify what the switch is, it's name and where I can source a replacement, i've been to B&Q and I can only see pull cord switches that support L1, L2 and COM ( so basically 2 way Lighting ) . and they look totally different to what I have already installed.
What kind of ceiling rose / pull cord switch is this? and where can I buy a replacement?
2015-04-15 13_opt.jpg (23.93 KiB) Viewed 2973 times
I realise I may have to consultant an electrician at some point as it doesn't look as straight forward as I had hoped, however before this I would like to source a replacement switch, which I am finding very difficult to do.
diydoctor6
Re: Identify Pull Cord Ceiling Rose in Bathroom Attached to Fan Extractor
by diydoctor6 » Mon Sep 07, 2015 12:19 pm
This is the information that you require: https://www.diydoctor.org.uk/projects/pu ... switch.htm
However if you are not confident, I'd strongly advise getting in a pro. Find one here: https://www.diydoctor.org.uk/find-tradesmen/
It is currently Sat Sep 28, 2024 10:43 pm
