New Shed Base Layed Over Area that is Currently Brick Weave?
BadgerBoy
by BadgerBoy » Sun May 03, 2015 5:59 pm
Hello there.
I need to put a new small shed onto an area which is currently a brick weave path/patio.
Could I lay a shed directly over bricks or should I pull them up and lay slabs? Or any other options?
Thanks for your help.
diydoctor6
Re: New Shed Base Layed Over Area that is Currently Brick Weave?
by diydoctor6 » Mon Sep 07, 2015 11:38 am
So long as the brick weave patio/path is solid then you can us that. If you want to spread the weight you could use slabs, but they will crack if the bricks move underneath - they have to be solid.
It is currently Mon Dec 23, 2024 3:13 pm
