Shower Mixer Fittings for Antique Shower Mixer onto Copper Tails
Greenseeder
by Greenseeder » Sun May 31, 2015 1:10 pm
Can anyone guide me on the appropriate fittings to attach this antique shower mixer to 15mm copper tails protruding from my plasterboard bathroom wall? Thanks
proptech
Re: Shower Mixer Fittings for Antique Shower Mixer onto Copper Tails
by proptech » Mon Jun 01, 2015 9:50 am
Hi Greenseeder
You need access to the other side of the plasterboard in order to use those back nuts. The threads look like 1/2 inch from the photo. To check that they're not 3/4 have a measure, 1/2 is very approx 7/8 inch dia. Therefore you will need some 1/2 PSP to copper fittings
Having said all that, the very best thing to do is to take the shower into a proper plumbers merchants (not a DIY store) together with a photo of what the copper tails are, and get them to supply you.
Greenseeder
by Greenseeder » Mon Jun 01, 2015 8:17 pm
Thanks for that prop tech. I have access behind the pboard so will give it a shot as you describe, via PTS. Cheers
It is currently Thu Dec 26, 2024 9:41 pm
