Suitable for Permanent Use When Used to Extend Water Supply Pipes?
articoceanic
by articoceanic » Thu Jun 04, 2015 12:45 am
Hello
http://www.screwfix.com/p/wras-hose-15m ... _container
Does anyone know if these are suitable for permanent use connected to the water supply?
thanks
BACKGROUND
I'm installing a douche shower spray near toilet, and need to extend the water supply to it, as no pipes nearby. Was thinking of attaching these to the pipes underneath the bath tap and extending the water supply that way.
But then read that shower hoses can't be permanently attached to the water supply, due to wear and tear from changing water pressure causing them to leak.
Was wondering if these are different and are suitable?
proptech
Re: Suitable for Permanent Use When Used to Extend Water Supply Pipes?
by proptech » Fri Jun 05, 2015 11:53 am
HI
These are for permanent use, but what you seem to be suggesting sounds like something of a total bodge. There are also special regulations covering this type of ascending shower.
articoceanic
by articoceanic » Fri Jun 12, 2015 12:55 am
thanks
It is currently Thu Dec 26, 2024 8:40 pm
