Sockets / Sinks. Help !
Shane
by Shane » Tue Aug 07, 2007 8:14 pm
Hi . can you help. Have two double sockets one on each side of a gas cooker,both 90mm away.
A fused switch 70 mm from the edge of the sink.
A normal double socket under the sink almost underneath the top of the outlet of a dishwasher. ( 60mm from plug to side of vertical pipe )
My P reg man says this is all OK.
?? Where do I go from here ??
BLAKEY1963
Re: Sockets / Sinks. Help !
by BLAKEY1963 » Tue Aug 07, 2007 10:56 pm
[quote="Shane"]Hi . can you help. Have two double sockets one on each side of a gas cooker,both 90mm away.
?? Where do I go from here ??[/quote]
SHANE
SOCKETS SHOULD B AT LEAST 300 MM2 FROM COOKER AND
300 MM2 FOR FUSED SWITCH FROM EDGE OF SINK.
INFO FROM GUIDANCE NOTE 1 IEE SELECTION AND ERECTION OF EQUIPMENT.
AS 4 THE DOUBLE SOCKET I WOULD ASSUME IT WAS ON THE RING AND NOT A SPUR. AND IT BEING SO CLOSE TO THE OUTLET OF THE DISHWASHER IT SHOULD BE A WATERPROOF TYPE WITH SNAP SHUT COVER OVER PLUG.( I INSTALL THESE TYPE WITH LOW LEVEL WATER FED APPLIANCES, EG WASHING MACHINES DISHWASHERS , AND THEY R NORMALY FED FROM WORKTOP LEVEL SPURS ON THE RING , AND TO FEED THE APPLIANCE A SINGLE SOCKET FOR IT NOT DOUBLE )
I CANNOT COMMENT ON WHAT YOUR P REG MAN HAS DONE
BUT AS A PART P MAN MYSLEF THE COMMENTS I HAVE STATED IS HOW I WOULD INSTALL IT.
BLAKEY1963.
Shane
Inside / Outside Circuits
by Shane » Wed Aug 08, 2007 9:16 pm
Already have outside light and socket circuits. Spark has spured of new kitchen extension ring to outside double socket.
Kitchen lights go to outside light 6 amp RCD.
This cannot be right.
It is currently Mon Jan 13, 2025 2:20 am
