How to Remove an Old Concrete Shed Base Crumbling
phil2471
by phil2471 » Sat Jun 27, 2015 9:05 pm
I have an old concrete base with shed on top and it is all crumbling.
Plan is to remove crumbling concrete and lay pavers over the top
some areas are a lot higher and there is a height difference of about 3 inches from shed entrance to edge of concrete
will I have to remove all concrete to a level base or can I build up using sand /cement mix
is the best way using a grinder or chipping away with sledge hammer
what depth of sand /cement for pavers
fireside
Re: How to Remove an Old Concrete Shed Base Crumbling
by fireside » Fri Sep 04, 2015 3:03 pm
Not sure if you can get away with laying over top, will leave that reply to others, but if you do need to remove concrete get a sds rotary hammer drill. I used mine they will brake up concrete easy. Can be got from argos for around £50.
Good luck
It is currently Mon Dec 23, 2024 2:51 pm
